RPP October
Results 11 to 20 of 20
Thread: CMAX Assembly Instructions
    Cary, NC
    Default CMAX Assembly Instructions
    Step 7.2: Linked rear suspension installation
    GCM offers rear link kits to fit a range of wheelbase options:
    - 277mm (10.9") fits from 274-280mm (10.8"-11")
    - 308mm (12.1") fits from 305-311mm (12"-12.2")
    - 330mm (13") fits from 327-333mm (12.8-13.1")
    If you are using the GCM front links, you can also adjust the wheelbase at the front by an additional + or - 3mm. If you are using a body with a different wheelbase, you can make your own links to suit your build.
    Start by assembling your links:
    Click image for larger version.
Name:	CMAX links.jpg
    Link assembly video:
    Attach links to side plates:
    Note the use of 3mm spacers inside the c-channel rails for proper spacing of the upper links:
    Attach links to axle:
    [picture to be added]
    Install dampers and coils. If using ECX 1/18 shocks, refer to step 6.5 for mounting instructions:
    Damper installation video:
    BowHouse RC, Helios RC, GCM #tinytruck Team
    Cary, NC
    8. Electronics
    Battery tray video:
    Cary, NC
    9. Body mounting (1 of 2)
    Cary, NC
    9. Body mounting (2 of 2)
    Cary, NC
    Reserved
    Cary, NC
    Updates:
    12/14 - added rear leaf suspension installation
    Cary, NC
    Updated 12/16: Added rear linked suspension installation
    Great thread. It has helped me out immensely.
    Cary, NC
    Thanks! Glad you’ve found it helpful.
    Cary, NC
    In case you missed it, Roo ran into a little snag assembling a t-case this afternoon while Dad was working in the yard.
Name:	Roo at the bench 1.jpg
    So he took it upon himself to post his sentiments thusly:
    HELP HELP THIS THING IS IMPOSSIBLE TO BUILD!!!!!!!!!!!!!!!!!
    But we got through it. Did I mention he's now built more of these things than Dad has...?
