Results 1 to 1 of 1
Thread: Scale Rotors from SuperShafty
    Sep 2015
    Default Scale Rotors from SuperShafty
    SuperShafty is proud to bring you its first scale item. Scale Rotors.
    Check these out. They come in a sand blasted finish, are 30mm ain dia and 2mm thick. They mount using the same bolt pattern as Vanquish wheels so mounting should be easy.
    Only $20 for the set of 4 exclusively at SuperShafty.com
    Grab a set today and add that awesome touch to your tiny trucks.
    #supershafty #bombproof #scalerotors
