RPP VS4 2018
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: GCM Scale Trans Combo Kit now ready!
    Default GCM Scale Trans Combo Kit now ready!
    Here's a package that will be easy to adapt to any scale truck build, and has mounting options that make it easy. We have a new combo based on the SSD lower geared transmission and our proven LRT2 and motor plate which allows for some much better low end control in our TinyTrucks.
    Check out the link and items here >> GCM Mount, Trans, and Tcase Scale Combo <<
    This new combo set works especially well on the small-count ring and pinion axle sets we see in the market today, such as K44, Yota II, Vaterra, and SCX2 trucks.
    Using hand picked GCM and SSD components, we have assembled the scale truck builder's dream drivetrain including a right or left side drop transfer case in every package. Start your next custom build with this beautiful and strong scale combo, and add some engine cover flair with our GCM Motor kit components as well from the >> Shapeways Store LINK << here.
    Included in this combo is the following:
    1x full GCM LRT2 Tcase -Left or Right drop, overdrive front shaft output already built in, 5mm output shafts and thru-pin holes.
    1x SSD built scale Trans, made to order just for this GCM Combo, including all steel gears and shafts, aluminum case, and a 14.3:1 gear ratio as per our spec.
    1x GCM motor/Trans mount plate with 4 threaded mount holes and hex hardware.
    This package has been hand picked to work flawlessly together, with the GCM motor mount plate, the ALL NEW SSD R5 trans (custom geared for this combo), and the LRT2 T-Case. We picked all steel shafts and gears for this unit to supply a reliable comp-worthy scale drivetrain setup.
    Mounting the unit is easy. We included hardware and 4 M3 threaded holes in the mount plate to allow easy L bracket mounting to just about any build. We also included 2 M2.5 screws to use in the back of the LRT2 case in place of the lower setscrew plugs for securing a crossmember to the back of the T-Case.
    This LRT2 case is the same as our current LRT2 offering that fits the RC4wd R4 trans, but we have changed the shafts and gears to work with this GCM combo, and the internals will not fit the RC4wd R4 transmission. The motor plate supplied in this combo is the same unit we have offered for a long time.
    Jun 2012
    Northwich, UK
    Just today placed my order for one of these . It shall be an excellent addition to Project Portal
    Thanks, Pete! It shall!
    I'm considering using it for my MadMooseRC portal build as well!
    That is a sexy transmission.
    Skickat från min iPhone med Tapatalk
    Mar 2016
    Maryland, USA
    Will the combo be available to the US store too? Got to have this for my MadMoose project too
    Lots of plans but no time to execute...
    Jul 2016
    Quote Originally Posted by Jrkilburn View Post
    I was wondering this too. I was going to preorder from the canada store but wasn't sure how well that would work.
    Yes sir! We will have this in the USA store shortly!
    Here's the total kit assembly video just for this unit! http://gcmracing.ca/viewitem.php?productid=357
    Mar 2016
    Maryland, USA
    Ordered from Canada store and received it quickly. Awesome product and build support!
    Sent from my iPhone using Tapatalk Pro
    Thanks! Happy building!
    Jul 2016
    Did the preorder and got it really quick. Its sitting in my TF2 waiting for electronics.
