Check it out at GCMRacing here >>AT THIS LINK<<
New to the Leaf Kit lineup, we have joined the short shock kit from our scale Broncos and put it together into this all complete stage 3 package!
Eliminate the rear shock towers, take off the rear body mounts, and still keep a fully functional rear suspension with this Stage 3 Complete Kit. This kit will give you billet aluminum parts to make your full rear suspension sit on leaf springs and uses oil filled shocks outboard for amazing hop control. Want a full interior? This will give you TONS of space!
This conversion kit keeps the same wheelbase you currently use on the Ascender platform, whether it's the Blazer or the Bronco, or a custom body with the same link setup.
The kit contains all the items to assemble on the truck, and we offer a Tamiya 9808091 leaf spring option to add to your kit. If you want to use a softer leaf spring, we recommend the Red RC4wd or TF2 leaf spring. You can also tune the suspension using helper springs under and over the main leaf.
There are 3 positions for mounting the front spring hanger, as well as the rear swing hanger. Use these 3 positions to tune your wheelbase and adjust for the leaf spring length.
Includes:
2 new outboard oil shocks (oil not included)
2 sub frame extensions
2 axle spring mounts
2 front spring eye mounts
2 rear swing hanger mounts
2 rear swing hanger bushings
2 spacers for eliminating rear bumper mounts
4 spacers for eliminating rear shock towers
Hex hardware
