Vaterra
Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 57
Thread: H3 build/rebuld
  1. #21
    I got the rear lights in tonight. Wanted to get that done before I got all the finish work done just in case I messed it up.
    Also started cleaning up the front.
    Have a few things on the way from RPP. Hope to start on the new rear bumper soon.
  2. #22
    Feb 2013
    Val-des-Lacs Québec
    I do not like Hummer, but it's a nice build
  3. #23
    So deciding if I want to use this winch bad enough to cut the grille..
  4. #24
    Apr 2014
    Cut it at the exact shape.
  5. #25
    Or....
  6. #26
    That should work... Ended up cutting the grille. Mixed feelings but it's done.
  7. #27
    That doesn't look so bad with the grille cut. Sometimes you gotta do it.
    SBG Junior Vice President RC4WD Team Driver
  8. #28
    Time to tweak it a bit.. Sunk the winch as far as I could
    And pieced the grill back around the winch as tight as I could.
  9. #29
    May 2014
    Deep within Google Sketchup
    Very clean cuts there! Looks pretty good to me.
  10. #30
    thanks, it worked out well since I cut first then dropped the winch, gave me a way to fill back in. I did have to splice in some pieces I cut back out. But in the end I think it works well.
    Now maybe I can start the new rear bumper
