RPP ProLine 2018
Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 95
Thread: Axial Jeep Build Off - M725
  1. #21
    Apr 2012
    Newcastle, NSW, Australia
    Quote Originally Posted by pedemasterrc View Post
    This will be a cool project. The last m725 in the sand. I know the owner of the truck. Its at silver lake sand dunes here in michigan
    That's coooooool!
    Some more progress. Have added the rear wall of the cab.
    And getting the front end together.
  2. #22
    Oct 2014
    QLD, Australia
    That's looking great! I love it! Very interesting looking truck.
  3. #23
    Feb 2015
    Tavastia, Finland
    So cool and so aerodynamic! Sweet build.
    I will leave "The Brave Little Toaster"-references for next time.
  4. #24
    Apr 2014
    Now that's a loaf of awesome.
  5. #25
    Mar 2015
    Nice blocky jeep!
  6. #26
    Apr 2012
    Thanks very much fellas!
    Some nice progress has been made of late. Have been working on the front.
    Started by sanding down the curves.
    Next was to add an outer couple of layers of 0.5mm sheet with various details cut out.
    The plan was to do the same across the top to give a nice smooth surface of the bonnet. However, when I bent the sheets over and glued, disaster struck. Seems the sheets are too thin and glue (solvent) is too strong, causing the sheets to crack. After it happened on one side, I tried heating the other side to aid in the bending, but applied a little too much heat and the sheet buckled a bit. So now that side of the bonnet has some nice "dents"! I will file down the cracked parts and use some filler, but they'll probably act as a good base to do some weathering. Rust will make that look good!
    This crack here has been filed down nicely.
    The other side is worse.
    But despite that, it's turning out pretty good in my eyes!
    Added the centre piece of the bonnet with just a little bend added using Scaler's method of working it in by hand. Thanks mate, it's surprising what you can bend just by hand!
    Still some work to do in tidying it all up, but I'm pleased.
  7. #27
    I'd agree with you Shannon, those are pretty minor issues to have to deal with. Overall, the look is spot on. Bust out the filler and you're good to go!
  8. #28
    Dec 2013
    Sydney Australia
    Way to go my Friend!!!!!
    This thing is going to be great.
    Cheers
    H2Micr0
  9. #29
    Oct 2013
    Tasmania, Australia
    Looking great! I've never seen styrene crack like that, unlucky! I gotta say I kinda like the pattern of those cracks though... looks like a dodgy 1:1 bog job gone bad! maybe you can work it in?
  10. #30
    Tough break on the cracks. It helps to bend by hand first even just a little before adding solvent. Especially with thin material. Keep up the great work!
