RPP Cross 2018
Page 1 of 27 1234511 ... LastLast
Results 1 to 10 of 266
Thread: Unimog Flatbed
    Jun 2012
    Northwich, UK
    Default Unimog Flatbed
    Whilst randomly searching on the interweb I stumbled across this picture
    ooh that's nice I thought closely followed by I could build that
    so I started searching for more pictures of it and struck lucky as I found some on benz-world.org
    It's a Unimog 404. But I am going to start off with a Tamiya Unimog 406 shell, as they look fairly similar (later I will have a go at scratch building a 404 cab).I will also be leaving the canvas roof and windscreen off as I am not very keen on them.
    I already have a set of Gmade portal axles (removed from my Wreckluse, which is undergoing a strip and re-build). I also scored a RTR Honcho which is almost brand new, for less than half price as a base vehicle.
    Today I actually started on the build (I am waiting for the some bits to arrive before I can really get on with the build.)
    first step is to narrow the axles
    Started with the rear as that's easy.
    Just chopped a 1/2" off each output, and drilled the end out to take the bearing in the new position (still need to shorten the shafts which I will do in the lathe at work.)
    Nov 2013
    London
    Always fancied doing a Mog looking forward to seeing where this goes
    Nov 2013
    Lincolnshire, UK
    Me too. Subscribed mate!
    Feb 2012
    Breezand, Netherlands
    I like the Moggies!
    Jun 2012
    Northwich, UK
    Thanks guys, I think the biggest challenge is going to be replicating the suspension links,
    but I have a couple of ideas
    Jun 2009
    on some moors in North Yorkshire,England
    Looking forward to this Pete
    Any use?
    have a look at the bottom of this link loadsa details
    http://unimogshop.com/the-mog-shop-m...for-sale-1329/
    This should be fun to watch! Looking forward to more updates.
    Check my Land Rover Series II thread for more help narrowing Gmade Axles.
    Nice Start - IDK how you are going to copy the torque tubes off the 404.
    Build on!!
    Sep 2012
    MA, USA
    This looks like an exciting build!
    Jun 2012
    Northwich, UK
    Quote Originally Posted by doublej View Post
    Build on!!
    Had a bit of a play around tonight and I think it's going to be do-able ,
    So I had some 12mm OD steel tube with a fairly thick wall. Took a stepdrill and opened out the inside diameter to 10mm at one end
    to take a 10x5x4 bearing
    Then opened out the bearing land in the diff nose from 11mm to 12mm to take the tube
    Next step was to chop up a perfectly good junfac propshaft a length of 5mm rod was then sleeved out to 6mm to slot into the end of the shaft (this will all be silver soldered together when I am happy with it)
    and all slotted together
    ran out of shed time tonight , but the next step will be to make the brace arms and to trim down the 5mm rod and shape it to take the pinion gear.
    The 1:1 rig has a wheelbase of 2700mm or there about's so I am going to shoot for approx 10 3/4" inches. Tire wise I am leaning towards a 1.9 Rock Crusher XT II on a 2.2 wheel (just not sure what wheel yet)
    More soon,
