Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 67
Thread: Nigelpheron's Micro Landscapes
  1. #21
    Mar 2008
    Uppper Riverbank
    Default Rocks done
    Got all the rocks blended in, and land-slide debris done. I just have to add a few more trees, the I can start on the waterfall / pond feature.
    An aquarium water pump will go in, and then the ponds will get thier surface details. I used different sized tallus to do the pond's gravelly bottoms. Intake and outlet fittings will be hidden, then all airbrushed to give a look of depth, and age-stained waterlines.
    Then I can fill it and try it out.
  2. #22
    kyle_l Guest
    holy #$%^ that looks awesome man.
  3. #23
    Mar 2008
    Uppper Riverbank
    Thnax.
    I can't wait to crawl on it. Actually, I'm going to wire the un-finished crawler, and have a go at it.
  4. #24
    Jun 2010
    Wasaga beach, Ontario
    all i can say is WOW
  5. #25
    Mar 2008
    Uppper Riverbank
    Default All done (sort of)
    Skip this reply.
  6. #26
    Mar 2008
    Uppper Riverbank
    Default Pump's good
    I tested the cheap pump, and it works good. Dollar-store+1
    I just have to install it, and do the water-area airbrushing. Stuff like greenish algae around the wet-perimeter, and dark silty areas to give depth.
    Like this I found:
    http://home.earthlink.net/~gerryleon...lakebottom.jpg
    Here it is so far, with just the water areas to do:
    And a video tour:
    http://www.youtube.com/watch?v=jyVxhGqkiOU
  7. #27
    This is one of the nicest living room accessories I've ever seen!
  8. #28
    Nov 2009
    Pooh corner, Ont. Canada
    Wow! Really nice man. Love it.
  9. #29
    Mar 2008
    Uppper Riverbank
    Default Air-brushed
    I just did the air-brusing. A couple different greens, and a couple different blacks, followed by a clear to seal it all.
    Tomorrow will see water...
  10. #30
    Mar 2008
    Uppper Riverbank
    Default It leaked
    Got some epoxy mud smeared under the leak. That should do it.
    And, the water pump is to weak. (should have learned from a previous post on trickling water in your scene). I want it to pour down the falls with some trickling noise. With this pump, you can only see the water slightly trickling.
    Anyhoo, here's a vid of a very steep area. Nevermind that unfinished rig.
    http://www.youtube.com/watch?v=WTL0qvUwsKU
