LockedUp RC
Results 1 to 6 of 6
Thread: Diff Width?
    Mar 2010
    Abby, BC
    Question Diff Width?
    I think this qualifies for this section. I'm building a Gasser with a differential drive. Currently I have an Axial axle but with the wide tires I have for this build it is a little too wide for the body I have. I either need to cut the fenders more (not feeling it) or raise the back end (not liking that much) or change to a body with a more open fender design.
    Has anyone taken the time to measure the different popular axles out there for width from hex to hex? Gear ratio would be cool too.
    madhatter Guest
    I don't know the a actual numbers, but TLT is the narrowest except for a semi diff or MRC.
    Mar 2010
    Abby, BC
    Thank you, good to know. I'm just assembling a CC-01 so I'll compare that diff to the Axial as well.
    We should get a full chart together, would be handy for all of us!
    koomz Guest
    mrc axles are 5 1/4 hex pin to hex pin just about 6 1/4 end to end.
    LAV25 Guest
    Tamiya semi rears are nice and narrow, designed for duallies so you'd have to cut odd a bit of axle.
